  #37 (permalink)
Old 01-07-2010, 07:10 AM
Anthony Anthony is offline
Cobra Make, Engine: CSX4000, 427
Originally Posted by Excaliber View Post
The "average" wage is a miss leading indicator of the reality of the middle class. A concept you seem to be stuggling with.
The UAW "average" wage is $65 to $75 an hour, including benefits, depending on your source. Thats about 115-120K a year. UAW and Republicans consider this group to be part of the middle class. They too are struggling with the concept. The problem is, "simple math" goes right over their head.
The "average" wage, is the "average" wage, whatever it may be, determined from elementary mathematics. I think you have the problem understanding what the "average" is.
You made the connection between "average wage" and middle class, not me or anyone else
$65-$75 / hr is actually like $130-$150 / yr. It's simple math, your calculations, as usual, are incorrect.
Let's review: Middle is self explanatory. 50% above, 50% below. Did you flunk 6th grade?
Middle is not average. There is a mathematical term for middle, it's called the median. I learned that in 7th grade, although I flunked 8th. It appears you flunked 3rd.
I can see why you're divorced. If I was married to you, the only way I would keep you around is if you had a tight A-hole. Squeeeeelllllll.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
