  #26 (permalink)
Old 01-07-2010, 09:40 AM
Gunner's Avatar
Gunner Gunner is offline
Cobra Make, Engine: ERA 707, 446ci FE
Originally Posted by bobcowan View Post
But, unless you're tracking the car, the Accusump is not necessary. It adds weight, complexity, expense, and leak points that you really don't need.
Just a correction, I wasn't the one who posted about the Accusump.
Anyone use/used oil heaters as a reasonable option for reduction in wear? Most seem to need to be mounted to the bottom of the pan, a chancy location in these ground-scrapers. It does seem like 100W or so of heat applied for an hour before starting would help in many ways.
= Si Opus Quadratum vis, angulos praecidere noli. =
