This is similar to the setup we use everyday, -- I will make up an article on this.
V-- you may have to play with geometry a bit. -- if you move the rod from the slave cylinder -closer to the trans you improve geometry.
it will pull a further distance in the clutch, for the same amount of travel on the cylinder. --
Steve
