Old 01-08-2010, 10:03 AM
Anthony Anthony is offline
Cobra Make, Engine: CSX4000, 427
Originally Posted by Gunner View Post
And is the same frame used in the aluminum cars?
It is, and it isn't.
Supposidly, the aspect of the frame that includes the engine and suspension pick-up points are the same. The difference between the fiberglass and aluminum car frames is where the body attaches to the frame. The alumijnum cars have a greater "bird-cage" body supporting frame than the fibergalss cars, where the fiberglass body doesn't need as extensive of a supporting structure.
You can convert a "fiberglass" frame to an alumimnum one by welding on the necessary body supporting subframe.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
