Old 01-09-2010, 05:06 AM
Default Make your own
priobe Make your own. It's easy. Get a piece of 8x10 gasket material and draw out the shape you want. Cut it with a razor. Same for the inner opening. Should take about 10 minutes, take your time. If the first one lines up perfect, trace 2 more on the same paper and you have spares. No cork. You want the heavy dark gray or black gasket material. Thin coat of RTV on both sides and let dry, (24) hours, no leaks. Just make sure to not over tighten the bolts. This will crush the gasket and cause leaks down the road. Rick L.
