Old 01-10-2010, 07:00 AM
jhv48 jhv48 is offline
Originally Posted by WardL View Post
How often does this happen? It seems crazy to have a clutch that occationally needs adjustment, but there is no way to adjust it? How was it installed and adjusted at the build?
The slave has a solid arm with a bulge on the end that nestles into the depression on the fork. The only way to adjust this kind of slave is to remove or add shims (mine had 4 originally) to the slave mounting bracket that function to move the slave cylinder either closer to or farther away from the fork. A very time consuming way to adjust the clutch I might add.
Jim
