Old 01-11-2010, 05:36 AM
priobe's Avatar
priobe priobe is offline
Cobra Make, Engine: E-M Cobra Ford FE 427 w/ Webers 48 IDA
Concobra,
Thank you so much for the offer. I actually received the pushrods and installed in the motor. Apparently, the adjustments I made were right on the money. The threads under the body were 2 threads.
Also, since there is not much of anything else to adjust the roller tip is centered on the valve stem.
Now, as crazy as this may sound, after firing up the motor and letting it warm-up it sounds different.
I mean, it does not sound bad or anything but the pitch of the motor sounds just different. I had a chance to take it for a short spin and everything seems fine. I will keep an eye on the rockers for awhile.
Thanks for the offer.
