Old 01-12-2010, 07:14 AM
priobe's Avatar
priobe priobe is offline
Cobra Make, Engine: E-M Cobra Ford FE 427 w/ Webers 48 IDA
Originally Posted by markha View Post
I am starting in 3rd gear at about 2000 rpm and as you can see from the log, I get a lean spike at 2800 - 3000. Help. What should I trying changing? .
I would change to a F11 tube.
This would richen up your transition.
But in my opinion you idle circuit maybe too rich. I think your 70 idle jet is way too rich.
I would first concentrate on your idle circuit then transition with main.
too rich on the mains if I am reading the graph correctly.
So technically you are running rich except where you indicated
