First of all an engine with a roller cam will be able to use a smaller fuel jet in the idle system because it will create a stronger depression signal in the manifold due to faster valve action. Go to a 60 fuel jet and 100 air holder and reduce the idle mixture screws to 3/4 turn open (max 7/8). After Idle system is resolved Then reduce the Fuel & Air Correctors on the main system to approx 160-165 fuel with 210 or maybe 215 air corrector. Leave the Emulsion tubes as they are F16's. Keep an eye on your plugs. If it spits through the carbs off of idle it's lean. Make all adjustments with it thoroughly warmed up.
Rick
