Old 01-14-2010, 07:45 PM
StreetSnake StreetSnake is offline
Default Wilwood balance bar slop
Now that I am waiting to receive my slave cylinder and plate from @ gcperf.com, I thought I would move on to fixing my crappy brake performance. I have wilwood 12.18 drilled and slotted in both front and rear. Both masters are 7/8". I have a wilwood forward swing triple master cylinder pedal assembly. One problem I found was the pushrods were threaded all the way in, so I back them out, the front being out further than the rear. Now comes the balance bar issue. That thing just slops around in there and really doesn't seem to be doing anything. I can adjust the threaded bolt over toward the front or back and it doesn't change anything. The problem is because of the slop, the right side (rear master)hangs all the way down causing the clevice to bind the pushrod. Any thoughts.
On another note, I don't have a ton of room in there to back the pushrods out because it extends the pedal decreasing leg room, minimal to begin with, and with the brake pedal extended it get in the way of the clutch. Would a floor mounted systme give me more room????
Wow that was a long post, hope you made it through without drowsiness.
