Old 01-15-2010, 08:02 PM
scottj scottj is offline
Cobra Make, Engine: Everett-Morrison, 434 cid
Balance bar clevises should have .10" clearance per side. Push rod length should be adjusted so that the balance bar rod is parallel with the pedal tube, when viewed from above (or below), with moderate pedal pressure applied. The bar should be loose with no pedal pressure applied. The important thing is that nothing binds with maximum pedal pressure applied. If the ends of the bar will still move up and down when the brake is applied then it probably isn't binding.
