Old 01-18-2010, 05:51 AM
Car Nut Car Nut is offline
Originally Posted by DWRAT View Post
Why do I have 4 bleed screws on each brake caliper?
What a pain in the but to bleed the system but it is done and now my rears appear to be working.
Dan
I suspect that you have four to allow the calipers to be mounted in different locations either in front or back of the wheel center line. That said, air goes to the top of the piston bore and the upper bleed screws should be used (because that is where the air is).
