Old 01-22-2010, 11:58 PM
Baz's Avatar
Baz Baz is offline
Originally Posted by Zedn View Post
Congratulations Baz.
Thanks for posting a bit of detail about the test.
What brake set up are you using (calipers and master cylinder)? I was told last year that everything has to be from the same doner car but i need to reconfirm this with the Engineer. Did this topic come up at all?
How did the car perform only using front and rear seperately? Any spins?
Liam.
Hi Liam,
I am using Jag brakes front and rear with a VZ Commodore master cylinder. No problems there with the Engineer as it has a similar internal chanber capacity as the Jags, but is a better unit.
Fortunately no spins, just took a fair bit longer to pull up.
Baz
