Thread: clutch set-up
Old 01-23-2010, 12:57 PM
Larry Spillman Larry Spillman is offline
Cobra Make, Engine: NAF 1965 427 bodied w/Clevland 351 bored 60 over toploader 4 speed White and grey stripes
Default Clutch problem too hard
Originally Posted by dcs155 View Post
Hi, I have a classic roadsters cobra I built in 1997 and would like input on a better clutch set-up. The car has a ford 460 and tremec 3550 trans. The clutch pedel preesure is so hard that over the course of the last 12 years of driving the car I have bent three of the rods that run from the pedal to the master cylinder. I remedied that by making a new rod out of a 1/4 socket extension. I have tried three different tilton master clyinders with bores from 1/2" to 3/4" and still the same extreme pressure. next it pushed the bolts wich hold the master cylinder thru the fiberglass firewall, Obviously something is not right.
I am using a tilton hydraulic thro-out bearing and a 11" center force clutch with a diaphram style pressure plate.
Any help would be greatly appreciated!!!! Thanks, Dave
What would be a better set-up to use in my car?????
Your clutch must be a racing clutch on the street, What I have done is convert to a smaller master as that will give you more applied pressure at throwout bearing than a big master. The other thing that works is convert to a pusher throw out instead of a tilton puller,This solves a lot of problems and is smooth to operate. Contact me if you have any more problems. I mount the pusher on the side of the bell housing and alignment must be close or you will get too buch wasted motion from slave cyl.
