Old 01-24-2010, 07:00 PM
cdnus cdnus is offline
Cobra Make, Engine: 408w 500 h.p. 550 ft.lbs
3170---You might want to have your existing mufflers checked with a bore scope first.
I had 2.5" S/S mufflers that had a manufacturing defect in them that caused the front baffle to crack. That allowed the packing to be sucked/blown out causing the mufflers to be unbearably loud.
S/S replaced mine N/C with the new design baffle & so far they are good while cruising & quite loud when on the pedal hard, just the way they should be.
If the bore scope has a 90deg. mirror attachment like mine, you will be able to look right into the holes in the baffle for packing. My Snap On scope is long enough to check all the way from the turnout to past the front baffle on my pipes.
Craig
