Old 01-24-2010, 09:54 PM
Butlers24rth Butlers24rth is offline
Cobra Make, Engine: Butler with Chev 454, decently cammed
Default Relocating the diff
I did mine last year. I moved it 1 1/4 inches back.
Not too bad
I can outline
Remove IRS, have drive shaft xtnded 1 1/4
Shock mounts: Welded and additional 2 inch pc of steel to the back of the mount. drilled new holes 1 1/4 inches back. I also added gussets to the top to strengthen it.
Front tray mount: made a 1 1/4 X 2" solid pc of alum as a spacer bar, bought longer grade 8 bolts
Cut loose the rear Tracking/ adjustment bars from the frame. I simply seperated the angle from the frame keeping the Hime joint mounts all together then when I re installed the IRS I welded it back to the frame 1 1/4 back
The most work was the upper mount to the top of the diff. I used a pc of 2 x 4 x 1/4 tube on end and 4 in axis front to back, had to cut a contured pc to fit the frame crossover bar on the other end of the tube I cleaned up and re used the plate that attaches to the top of the diff. I gusseted this as well. You have to make/ buy new bolts to thread into the top of the diff as the old ones are too long to get between the frame and the mounting plate. Check before you weld.
I did all of the welding in the car using pcs of sheet metal as heat barrier.I am very happy with it and I have not broken it, at least not yet!!
Good luck, Scott
