Brake Bias adjusting in the Pedal box of your Butler
Hi Fellow Butler owners.
Have you found it to be difficult or is it a problem to adjust the brake bias on your Butler for perfect brake balance?
Seems to me that you would want an easier way to dial in the correct brake bias setting.
I'm thinking of installing a Wilwood, or similar, Bias adjuster with remote adjusting cable. This modification will make adjusting very easy, just turn the knob as you drive and test the result as you use the brakes. I've "heard" that for optimum street driving and track performance, bias settings may need to be different. What are your thoughts on this?
Has anyone done this modification?
Would love to know the details.
Thanks,
Arthur
Reason: more info
