Old 01-25-2010, 12:31 PM
RedBarchetta RedBarchetta is offline
Banned
Namely: the ERA has a larger 'x' member which runs from the door leading edge all the way to the main rear crossmember. This 'x' is one tube welded to 2 legs to make the 'x'. The H'cane shows the x rails cut short of the main rails and joined by short rectangular tubes to the main rails-obviously to lower the trans mount. ERA accomplishes that with a rectangular gusset welded just forward of the x. The trans mount sits on that pad and the tail shaft is above the 3" dimension of the 'x'. Trans comes out from the top.
Is Hurricane's intentions to have a design in which the transmission can be dropped from the bottom? This is somewhat (depending on your own views) of a knock against both ERA and SPF, as pulling the seats and tunnel just to service a clutch sounds extreme. At the least the first time is a PITA...after that it isn't as big a deal.
Cool drawings.
-Dean
