Old 01-26-2010, 10:01 PM
Hray Hray is offline
Cobra Make, Engine: classic roadesters ltd, 302, T5
Update:
610 hours; 66 days down, 24 to go
We got the passenger side inner fender installed, we had to add some to the rear outside edge for the liner to fit the fender well adequately, will add some filler all around the edges tomorrow and sand smooth. passenger side has been modified and ready for install.
we also removed the doors again, (hopefully, for last time), I removed the hinges and installed a door stop on each hinge so the door hinge would not touch the fender upon opening it.
We had just a little too much dust and too much orange peel in the clear coat. it would have buffed out, but we thought it would be easier to sand and apply another layer of clearcoat instead of buffing it out. Got that done and it lays down much better and not a near as many dust nibs, We will just lightly sand the nibs out and buff that not the entire underside of hood and decklid.
Tomorrow we should be getting into the sanding the body for the last time and then cleaning and taping for paint. Paint will most likely be on friday. We will need a good 12 or more hour day to paint, tape, paint, remove tape, clearcoat it.
