Old 01-28-2010, 02:57 PM
Anthony Anthony is offline
Cobra Make, Engine: CSX4000, 427
Most of the S/Cs had 2 x4 on a medium riser (BC & BD). The Comp configuration was a single four barrel, BE (3255). This would have probably been the same set up if an S/C had a 1x4 fitted.
Most of the street 427s had 2x4 with most on a low riser (BJ and BK). Some had a 1x4 BV (3255-1),
I believe a few of the 428s came with a single Autolite carb.
(These are notes from prior threads on this topic)
Thanks. That's a bewildering assortment. Too much to ask-what are the differences among all those carbs? Like 3255 and 3255-1? BC / D / E / J / K / V's?
Holley has a reference book on their carbs, and the # 3255 is listed as a factory carb for a 427 engine ( I assume a crate 427 MR engine). The 3255-1 was listed by Holley as a factory carb for a "race 427 Hi-Riser engine", both the 3255 and 3255-1's were rated as 780 cfm with the "leMans" bowls.
Early on, I believe the 427 comp cars were advertised as being equipped with Hi-Riser engines, although the vast majority of them as well the S/C's were equipped with either the medium risers or some with low risers. I believe there were a couple of cobra's that came equipped with high-riser heads, and I think the Turd had these heads at one point, as the Hi-Riser at one point was Ford's crate "Nascar" engine, and probably came with the 3255-1 carb, which is rarer of the 2. I believe both carbs are identical except for the List #.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
