Old 01-29-2010, 06:30 PM
Woodz428's Avatar
Woodz428 Woodz428 is offline
Cobra Make & Engine: Coupe,Blue w/white stripes SB; Roadster, Blue w/white stripes BB w/2-4s; SPF installer/Hot Rod-Custom Car builder
Originally Posted by lovehamr View Post
For the Avenger I always thought that they were going for a GT40 Mk III look with that headlight treatment.
Steve
If you use the broadest terms. They used 4 headlights that were slanted somewhat. Once you get outside of the headlight bucket, you've entered the twilight zone.
I'd have to look at some of the MKIII pics, but I recall they used a set of smaller lights on the inner pair. The tail of the MKIII is more similar to the Kellison, a little longer than the MKI and II. Overall the Kellison is virtually a copy, whereas the Avenger was more of a "feel". That is comparing the 2 cars, I don't consider the Kellison a copy by any means.
Much like Cobras are always mis-identified that's the case with an Avenger, anyone that knows GT40s would never confuse the 2. The Kellison from certain angles may easily be confused with a GT40, but from other angles...no way.
WDZ
