Old 01-29-2010, 10:03 PM
jhv48 jhv48 is offline
Remember when you go to the BAR to make sure your valve cover breathers have a hose to the air cleaner or you'll be coming back for a re test.
No breathers can exit to the outside air as of 2009.
If you have one, you will fail. Easy to correct. Go to Kragen/OReilly and get a valve cover cap that has a breather hose and then run a hose from the breather cap to the air cleaner. Then disconnect it as soon as you pass if you want to.
Jim
