Old 01-30-2010, 04:41 PM
Gunner's Avatar
Gunner Gunner is offline
Cobra Make, Engine: ERA 707, 446ci FE
Originally Posted by jhv48 View Post
Remember when you go to the BAR to make sure your valve cover breathers have a hose to the air cleaner or you'll be coming back for a re test.
Took care of this long ago. I had to pull the turkey pan and S&H air filter since they had no good way to attach a breather hose. Put on a long oval, drilled the base plate for a breather tube to the oil cap (which I replaced with a closed, vented one). Then I replaced the rear open breather with a PCV tube fitting and ran an inline PCV valve to the base of the carb. Valve covers are as they were, un-breathered. All closed up, ready to make the BAR man happy.
One of the many things I would not have known without the input from CC.
= Si Opus Quadratum vis, angulos praecidere noli. =
