Old 12-20-2001, 05:08 PM
427sharpe's Avatar
427sharpe 427sharpe is offline
Cobra Make, Engine: A CSX Cobra,1966 GT350 and an '06 Ford Heritage GT
Question
'Pulled the brackets off?"..Do you mean the caliper brackets only, or did you remove all four bolts that retain the bearing retainer to the axle? If you have all 4 bolts out and the axle still will not budge, DO NOT use a torch! This can make the metal brittle or warp the flange seat and cause a leak! Try penetrant around the bearing mating surface to loosen up the bearing, and LIGHTLY tap on the bearing surface on the axle tube while pulling the axle (a 2nd 'helper' would be very nice!). It should require just a slight bit of pressure to pull the axle. The slip fit is important because it keeps the outer bearing race from spinning in the axle tube. When you get the axle out, reinstalll w/ a slight bit of anti-seize and you wont have this problem again.
"I think we have more machinery of government than is necessary, too many parasites living on the labor of the industrious." Thomas Jefferson
