Old 01-31-2010, 03:16 PM
Baz's Avatar
Baz Baz is offline
Originally Posted by mr0077 View Post
Baz, just a thought: The oil temp and coolant temp on mine pretty much follow each other, and your coolant temp was rock solid and normal, making me suspect the gage...you might want to check the oil temp sending unit or gage for accuracy. Also, seems that if the oil got that hot you would have smelled it; any light smoke or odor?
Yes, Thanks Ken,
I did notice on a couple of occasions, black smoke coming from the exhaust momentarily when the vehicle was started when the engine was hot. I thought it may be because the current engine tune is a bit on the rich side. I could also smell the oil when he came in to pit when the oil temperature was showing 150 degrees C.
Baz
