Old 02-01-2010, 09:35 AM
priobe's Avatar
priobe priobe is offline
Cobra Make, Engine: E-M Cobra Ford FE 427 w/ Webers 48 IDA
Originally Posted by FatBoy View Post
Yes.
The firing point doesn't move with the change in advance. The reluctor and rotor arm are fixed relative to each other, so once it is set, it is set for the full range of ignition advance.
Ok school time... Please help
Ok I thought when the the rotor moves (not the motion driven by the camshaft) advances, this is what causes the distributor cap to receive voltage before it is aligned on the terminal.
I am I wrong here.
[/quote]
The misalignment that necessitates the adjustment is between the rotor mounting and the reluctor and has nothing to do with the cap mounting. Therefore, once the phasing is set, you should be able to swap caps at your leisure without need for further adjustment.
Paul[/quote]
Then why are we referencing the to the terminal on the cap.
I'm confused?
