Old 02-03-2010, 12:03 AM
Hray Hray is offline
Cobra Make, Engine: classic roadesters ltd, 302, T5
tuesday nite update:
750 hours over the last 75 days, 15 days to finish.
For the last two days we have been sanding and polishing the body. the body is now done, and tonite I covered the dash with vinyl and began to reinstall the switches and guages.
We first sanded with 1000 grit, then went to 1500 grit, then with 2000 grit by hand, Then we used my air Dual action foam padded sander with 2000 grit first then sanded with 4000 grit, after that has all been done craig then began to polish with the air buffer foam pad on larger areas. i put the hook-it foam pad on my DA and got the front nose and rear and other corners and places were more care was needed.
The other parts are ready for air polishing. Craig will get those tomorrow and i will finishe up the carpet padding and carpet and install the dash. With a little luck we might get some bright work reinstalled.
there will have been about 75 hours invested in the paint sanding and polishing after the paint was on the car. We already have 40 hours in that activity. Can hardly wait to see some of the chrome up against the paint.
Criag and I agreed today that this paint job is the best job that either of us have produced, all metalic laid down perfect, no major imperfection so far anywhere.
Will have some pictures hopefully tomorrow nite, just too tired to take time up load tonite.
