Old 02-05-2010, 08:54 AM
madmaxx madmaxx is offline
Something is being missed. I have a TKO 600 with standard slave and bracket and it works perfect. The only issue I had was weaping because the bracket was not alinged with fork.
what transmission do you have? where did you get your bracket? Are you using the Isuzu slave cylinder which comes with SPF's. If you push in on the clutch can someone push you down the street? If so it is not your clutch.
