02-05-2010, 05:45 PM
GA
Cobra Make, Engine: Butler Cobra. 350 Chevy Engine, blueprinted, heads cc'd, ported, polished, manifolds matched, big valves, 1.6 roller rockers, TB Injected, mild cam, MSD crank trigger electronic ignition. TKO-600 transmission. XKE Jaguar rear. IFS by Fast Cars
Originally Posted by n6opv
Arntz never made it to 91" until the very late Type 4 cars. The most common Arntz, the Type 3, still had a 90" wheelbase although many have been modified, as you guys are discussing. Ron Butler made 60 of the Type 3 chassis for Arntz before he went under and subsequently, the first 30 or so Butler chassis remained unchanged until Ron decided to lengthen the wheelbase by 3/4" in the mid 80's.
Jason
Jason, My car was produced July 86 #42 Do you know if mine is of the final generation chassis?
I moved mine back 3/4" because that was "relatively" simple to do. This however, will still not center the wheel in the fender arch, it will just provide a little bit more clearance for slightly larger diameter tires.
Arthur
My Cobra build: http://apps.facebook.com/wildfire/fb...oid=1023096501
Reason: Link
