Old 02-06-2010, 05:14 AM
vector1 vector1 is offline
Cobra Make, Engine: jbl
sounds like electrical or ecu problems, maybe not a good ground, or during hookup any stray voltage go through the ecu? check all the wiring, you have to believe that roush had it running in good form or they would not send it out. if everything checks out on your end i would attempt to try their ecu, but you don't want something to happen to it. good luck, i chased efi stuff for quite a while before i gave up and went back to carb.
