Old 02-06-2010, 03:17 PM
madmaxx madmaxx is offline
My guess is any Roush 427 between 400 and 600. The numbers are stamped on the valve cover, and on the dyno sheet, and the roush plaq. Without a doubt my Roush has performed flawlessly from the day I got it, the installer addressed the carb issue before I got it. Oh did I mention Sunny, 65F and 40% humidity in Houston today. How that snow hitting you guys LOL LOL LOL LOL LOL LOL!!!!!
Originally Posted by Roush #1 View Post
Ward,
Just to add a bit to this mix .... my repair, from a blue dot to a green dot ....
did not involve a jet change, air bleed change, idle air bleed adjustment, or squirter change.
I checked all of these on the original blue dot and they were the same on the green dot replacement carburetor. What I am saying is the difference in the two carburetors on mine was not visible.
I am aware of one more Roush engine that was built about the same time that had very similar problems. I have heard there are more, but I do not know that for sure. Mine was number 444 and I think Maxx was somewhere about the same time.
Don't give up on the engine. It could be as simple as an air bleed adjustment.
I understand your frustration, but the 427R should not be "bucking like a horse" when it is properly tuned. Mine runs smoothly in any gear at 1,000 RPM and idles well at 800 RPM - and yours can as well.
Gearing has something to do with it and it should be more prone to buck at higher gear ratios (lower numbers), but when I am in 6th gear (.62:1 ratio) with 3.89:1 rear gears, not many Cobras are geared higher which normally causes the bucking.
Good luck!
Jody
