02-06-2010, 08:40 PM
GA
Cobra Make, Engine: Butler Cobra. 350 Chevy Engine, blueprinted, heads cc'd, ported, polished, manifolds matched, big valves, 1.6 roller rockers, TB Injected, mild cam, MSD crank trigger electronic ignition. TKO-600 transmission. XKE Jaguar rear. IFS by Fast Cars
Good information to read on brakes at the following link.
http://www.stoptech.com/tech_info/wp...g_valves.shtml
So is it possible to have two master cylinders front and rear as the Butler has with the balance bar, and install a brake proportioning valve like the Wilwood #260-8419 http://www.wilwood.com/products/006-...1-PV/index.asp on the rear master cylinder?
Will this valve add to the adjustability of brake bias control? Or is this valve designed to operate on a single master cylinder setup that operates all four brakes.
Arthur
My Cobra build link: http://apps.facebook.com/wildfire/fb...oid=1023096501
Reason: link
