Old 02-07-2010, 12:11 PM
Matsango Matsango is offline
Cobra Make, Engine: Antique & Collectible
found this on the internet, does it sound right
Lower arm to crossmember- 95-110
upper arm to frame- 95-110
stabilizer bar to lower arm-15-18
ball joint to spindle(upper&lower) 75-90 (tighten to minimum and then tighten to nearest cotter pin slot)
strut to lower arm 40-60
stabilizer bar to frame 6-12
shock upper attachment 22-30
shock to lower arm 70-80
brake backing plate and cylinder assy. to spindle 20-35
strut to frame 70-80
STEERING:
support yoke cover to housing 15-20
pinion cover to gear housing 15-20
steering gear to crossmember 80-100
connecting rod end to spindle arm 35-47(torque to 35 and go to nearest hole)
