Old 02-07-2010, 02:58 PM
Woodz428's Avatar
Woodz428 Woodz428 is offline
Cobra Make, Engine: Coupe,Blue w/white stripes SB; Roadster, Blue w/white stripes BB w/2-4s; SPF installer/Hot Rod-Custom Car builder
Originally Posted by CobraEd View Post
I think that the input shaft on the transmission is steel. The pilot bearing is usually bronze, so if anything is going to wear out it is the bearing. After you replace it, make sure you put some good synthetic grease on it
Really, you do need to grease it.
There is also a roller bearing option, I can't verify if they have a longer life or not, but it is an option.
WDZ
