Just so everybody knows, I was absolutely serious about using the wet toilet paper, instead of grease, to act as a hydraulic impact removal tool for the pilot bearing. You just dip the
new, unused toilet paper into a cup of water so that it makes a papery-goo and then use that goo as you would the grease to pack the pilot bearing hole. It's an "old school" trick and, believe me, TP is a hundred times easier to clean up than grease.
