Old 02-08-2010, 03:53 PM
767Jockey's Avatar
767Jockey 767Jockey is offline
Originally Posted by lal Naja View Post
BTW What kind of bolts are you using to attach your coilovers to the frame and lower control arm? See my other thread on the subject.
Also what bolts did you use to mount the Diff to the frame. I have grade 5 drilled heads for wire-locking them in place. I could not find grade 8 drilled heads bolts.
Arthur,
I used Grade 8 bolts with Loctite to mount the diff to the frame, and I used the stock Jag threaded shafts for the coilover mounts.
