Old 02-08-2010, 03:48 PM
joyridin''s Avatar
joyridin' joyridin' is offline
My Arntz has a rear sway bar that is about 1" in diameter or so. I'd have to look at it again to see for sure. It runs between the body and frame over the top of the driveshaft. The rear frame comes up at a 45 degree angle, then straightens out at the top. Right before it straightens is where the poly bushings are located. It uses adjustable links that connect to the rear lower control arms. The links are about 12" long and it has heim joints on both ends.
