Old 02-10-2010, 01:54 PM
RodgerH RodgerH is offline
Cobra Make, Engine: SPF 2592, Shelby alum. 527
Ok....thanks. Presently I'm using a rod with a rounded tip. A spring (same as in your pictures) holds it tight against the slave piston. Only problem is the rod length adjustment is at the slave cylinder end of the rod, so I have to slide the boot back to get to get to it. I may do something similar to your setup.
Rodger
