Old 02-10-2010, 03:54 PM
Anthony Anthony is offline
Cobra Make, Engine: CSX4000, 427
Originally Posted by RodgerH View Post
Do you have the p/n (or a source) for the pivot seat you used with your clutch fork? I checked with the local Ford garage and with RockAuto...both showed the fork you referred to, but neither had a reference to the pivot. The spring broke on my fork and I'm considering a different style.
Also, could you go into a little details on the fabrication of your adjustable clutch pushrod?
I used a BBC rocker pivot, slid over a hardened threaded rod ( from a leaf spring clamping U bolt ) with two jam nuts behind the rocker pivot. I ground the other end of the rod to a rounded shape that went into the seat inside the slave cylinder.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
