Old 02-10-2010, 11:38 PM
Hray Hray is offline
Cobra Make, Engine: classic roadesters ltd, 302, T5
Update: 83 days down, 7 days till we load it in the trailer.
Gonna back track some, someone wanted pixs of steering column, so here they are. first a little bit of explanation. I started with a complete 67 mustang column and a complete chevette column, I cut them both in half both the shafts and the column itself. The stang shaft slide inside the chevette shaft just perfect, we slid in inside about 12 inches so it would stay straight. we welded them together. we then took the bottom half of the chevette column and welded it to the top half of the stang column. we then fit a grant steering wheel to the top half.
here you can see the shaft and the column prior to assembly
http://farm3.static.flickr.com/2789/...91a37aab_b.jpg
here is a picture of the hood prop ratchet assembly from the 69 corvette
http://farm5.static.flickr.com/4048/...5d43eccf_b.jpg
here is the column installed in the car.
http://farm3.static.flickr.com/2779/...c6174a63_b.jpg
here is what the under side of hood looks like open and on the car
http://farm3.static.flickr.com/2768/...67408e10_b.jpg
here is shot of CRL badge on side. question was there a classic roadesters, then CR limited, then CRII or only the two.
http://farm5.static.flickr.com/4017/...15fe0ddf_b.jpg
Here is the roll bar installed, I forgot to take close up pix of the model A windshield rubber gasket up close, maybe you can see it. I thinks it look great protects the body from vibrations
http://farm5.static.flickr.com/4065/...d1757808_b.jpg
here is trunk opened, we ran out of black texture paint for trunk, will finish tomorrow and install trunk carpet.
http://farm5.static.flickr.com/4017/...e16da3e5_b.jpg
here is pic of rear tire, sidepipes, and roll bar, I like the silver on all three, I feel it follows theme, the chrome on outer rim ties in with mirrors and windshield frame.
http://farm3.static.flickr.com/2767/...d525fb97_b.jpg
side profile shot, I think I need to clean the camera lens,
http://farm3.static.flickr.com/2718/...d868721e_b.jpg
