Old 02-11-2010, 05:34 PM
Gunner's Avatar
Gunner Gunner is offline
Cobra Make, Engine: ERA 707, 446ci FE
I'm not convinced that synthetics are superior from a financial standpoint. They have advantages over dino oil in operation (mostly, better viscosity range and resistance to breakdown), but nothing stops them from accumulating sediment, acids, water and general goop.
There are three reasons to change your oil. One is to replace oil that's worn out through breakdown. Two is to get particulates out of the system. Third is to get toxic goop out of the system. Synthetics in light-duty street engines can tolerate longer change intervals because of the resistance to breakdown and most engines' tolerance for crud. I don't think I'd consider extending the oil change interval in a high-performance, old-tech engine no matter what oil I used - so I'd rather use good dino oil and change at 3-5,000 or once a year rather than "save money" by using more expensive syns and tripling the change interval.
= Si Opus Quadratum vis, angulos praecidere noli. =
