Old 02-12-2010, 06:27 PM
Cobra #3170 Cobra #3170 is offline
Default Tonneau Cover
Stuart,
In case you're not aware, you should buy a top or tonneau which has NO holes and grommets so it can be cut to match Jim's pattern or what ever else you use. Also a roll bar on your KMP may alter the way a tonneau is fitted.
The roll bar equipped cars had a tonneau zipper that allowed the cover to be closed around the roll bar. The zipper ran on the approximate Center line of hoop and was parallel to the axis of the car.
