Old 02-13-2010, 11:02 AM
A-Snake's Avatar
A-Snake A-Snake is offline
Original Shelby Owner
Cobra Make, Engine: CSX2321
With the rear view mirror having different mounting locations on cars perhaps the snap that is location in the front cowl in the horizonal position would be a better reference point. It should be the midpoint of the top of the dash area.
There are a total of 16 lift-a-dot studs used for the softtop. An addtional four are needed in the front cowl for a tonneau plus the one snap I mentioned above.
Four of the lift-a-dot studs on the rear cowl are in a straight line. The rear edge of the cockpit opening at that point is also straight so these should be easy to locate. The centers of these four studs are 13 3/8" from the cockpit edge. The center to center of these same 4 studs are 8" apart. (Total span 24") To check there location, measure from the horizonal snap on the front cowl to the most outboard of the four studs mentioned and it should be 49 1/4". If the two outboard measurements are the same, you can then use the 8" spacing between them.
Have to run right now but I will post later on locating the remaining studs and some pictures for reference.
More later
