Old 02-13-2010, 08:53 PM
mickmate's Avatar
mickmate mickmate is offline
Contemporary had a flat pattern of the rear lift a dots that works pretty well when you lay it out and line it up with the cockpit edge. I pictured doing the same with the front lift a dots. The only little obstruction is the rear view mirror but it is easy to remove or just slit the paper pattern to fit around it. It's kind of nice reversing these as if you just push them through the paper and trace the edge from underneath that will be pretty darn close. I agree tops and tonneaus are fitted to the snaps but a general layout is real handy to start with.
mickmate
http://www.actoncustom.com/
