  #36 (permalink)
Old 02-14-2010, 06:31 PM
ERA Chas ERA Chas is offline
Chas, I think you're 100% absolutely right, but even if my true system capacity was not known, I think you're method is way too much/difficult for the "Oil Change For Dumbies" type person that I am.
Rod,
You may not be conversant with Euclid as Pat and I is but you're a pretty bright guy- just fill to seven, your cooler and lines are already full and just add .75 to your filter.
Use a new crush washer on your drain plug and don't overtighten. You be good den.
Errata:
In my above rant I neglected to mention Gunner's cooler holds .5qt whch means his (and most of ours) system will be at near 9 qts.
Chas.
