  #37 (permalink)
Old 02-15-2010, 06:07 AM
DanEC's Avatar
DanEC DanEC is offline
Originally Posted by Dan Case View Post
Somebody asked about the ferrules in doors for side curtains. I can show you the pattern in CSX2310. I did this sketch for a CSX24XX car owner last year. The center line is for the holes and not the top of the door. Measurements were just done with a tape measure. The information was good enough for him to pick a set of curtains from those he found for sale that would fit his car. Yes, there are reproductions around that will not fit an original condition set of doors.
This is helpful and I'm going to check it out on my ERA body to see how it matches. Unfortunately my main problem is that the rear and middle ferrule holes appear to have been drilled too far to the outside on one door compared to the other door.
As a simple alignment check - does the rear most ferrule fall in general alignment (longitudnally) with the first lift-a-dot stud on the rear fender?
Thanks
Dan
