Old 02-16-2010, 07:58 AM
lal Naja's Avatar
lal Naja lal Naja is offline
Cobra Make, Engine: Butler Cobra. 350 Chevy Engine, blueprinted, heads cc'd, ported, polished, manifolds matched, big valves, 1.6 roller rockers, TB Injected, mild cam, MSD crank trigger electronic ignition. TKO-600 transmission. XKE Jaguar rear. IFS by Fast Cars
Originally Posted by CHANMADD View Post
The discs with the extra big holes are used on the Dana center section. Those two large holes are used to remove the calipers which bolt directly to the casing and not a an aluminum bracket.
Most of the aftermarket/replacement discs come with the extra holes.
The discs with the square drillings are for the Salisbury centre.
John
Thanks for the reply.
Do you know what years & models the square pattern fits?
Thanks,
Arthur
