Old 02-16-2010, 02:51 PM
Rick Parker's Avatar
Check the float chamber drain plugs, sometimes they will leak, be carefull not to overtighten. Secondly the floats may be sticking at shutdown causing fuel to drip out of the main discharge in the secondary venturi and then pool on the throttle plate and seep out of the throttle shaft bores. May have a little dirt in the needle & seat allowing it to leak instead if seal tightly. Check all the AN fittings too.
Rick
