  #38 (permalink)
Old 02-17-2010, 07:23 AM
wiley alexander wiley alexander is offline
Cobra Make, Engine: none
Wink coyote
Use a better oil. The anti wear additive packages in all SM specified oils have been removed. More friction causes higher temps. Use Royal Purple 5W30. It has 400% higher film strength than anything on the market. You will like the additional performance as well.
The lower oil psi is caused by the fact that it takes less energy to pump a ligher oil around an engine. You don't need higher psi to do the job.
