Old 02-17-2010, 06:36 PM
bobcowan's Avatar
bobcowan bobcowan is offline
That looks like red lock tite in there. You should probably apply heat before doing anything.
Removing the carb is so easy, I can't think of a good reason not to do it.
Be carefull with the drill. The metal of the carb is softer than the bolt.
That loos like a grade 8 bolt. If so, that's the reason you're in this pickle. Grade 8's are extremly strong in tension. But in situatuions like this, they can break. As your did.
I usually use a piece of All Thread, and a nice nut on top. I'v never had the All thread break.
